2006 Mule 3010 Diesel no starting
Discussion in 'Kawasaki SxS Discussions' started by HeyBlue697, Nov 30, 2013.
  1. HeyBlue697
    HeyBlue697 Starting Member
    Nov 30, 2013
    United States
    My girls were out riding and they turned the Mule off. When they went to re-crank all they hear is a click. My ride is a 2006 Mule 3010 Diesel. The lights work, the horn works, I checked all fuses in the fuse compartment, I cleaned the corrosion from the battery terminal, and I checked that I got 12 volts from battery. When key is turned on the glow plug light indicator goes off at warm up, the transmission is in neutral and all I hear is a click. Any ideas what to check next or does someone already know the problem and fix for this.
  2. carnivore
    carnivore Registered Member
    Feb 16, 2009
    5,420
    Grand Ledge, Michigan
    I'd pull the starter and jump 12 volts to it and see if it turns over
kawasaki mule 3010 no crank no horn
