Light bar wiring ?
Discussion in 'Electrical/Lights' started by upnover, Apr 27, 2015.
  1. upnover
    upnover Veteran Member
    Mar 19, 2010
    147
    18
    California
    Haven't been able to make time to wire up the new led light bar but as I was sitting there last night getting a game plan I thought of this. I am not fond of lots of switches so I am thinking about using the hi beam side of the stock switch to activate the light bar. I will still wire a separate fuse and relay for the bar but use the stock switch in place of adding another. Low beams would stay the same but when I flipped to hi beams the led bar would come on with the hi beams. What do you think?
  2. abkdad3
    abkdad3 SSW Director of Public Relations Staff Member
    Aug 19, 2010
    2,248
    Eaton Rapids, MI.
    Thats a good idea. I'm getting ready to put a light bar on mine and I might just do the same thing.
  3. pwm
    pwm Assistant SSW Rally/Event Director Staff Member
    Feb 18, 2011
    2,561
    Knoxville, TN
    Sounds like a cool idea
  4. slane01
    slane01 Moderator Staff Member
    Mar 8, 2009
    4,369
    Attica, Michigan
    Sounds like a great idea....and it sure would be a high beam :)
  5. upnover
    Mar 19, 2010
    147
    18
    California
    Well I finally got some time to start wiring and after looking at how well wrapped and insulated the stock wiring was decided a dedicated light bar switch was the way to go. Ended up placing a back lite switch on the back side of the shifter housing between the seats. Unfortunately the brand new relay I have appears to be bad from the factory so I ordered a new one as none of the local parts houses had one. I can jumper the relay and let there be light!!!
  6. pwm
    Feb 18, 2011
    2,561
    Knoxville, TN
    Any pics?
  7. upnover
    Mar 19, 2010
    147
    18
    California
    I need to trim the opening for the switch a bit better and then I will get a pic. I installed a switch I had but don't like it. Went by and picked up a switch that will be almost flush when mounted. It is an inexpensive switch but hopefully decent quality.
  8. upnover
    Mar 19, 2010
    147
    18
    California
    Here are a few pics. Need to finalize the wiring coming down the cage. I would normally drill the cage and run it inside but for some reason can't seem to bring myself to do it to this cage. I am going to see if I can't find some cage pads or handlebar pads to help hide the wire, maybe I can find one with Polaris and the logo on them.
