Polaris Ranger 800 Xp Transmission
Discussion in 'Drive Train' started by Milk-Lo26, Sep 5, 2014.
  1. Milk-Lo26
    Milk-Lo26 Starting Member
    Sep 5, 2014
    3
    New Athens,IL
    I'm having trouble with something in my transmission or rear gear housing!! It will periodically slip and then act like the differential is trying to lock and unlock when the switch is in single wheel or diffirential lock position!' Has anyone else had this kinda trouble? I have it pulled out of my ranger now and it's at a shop being worked on but their telling me everything is up to oem specs and can't find anything internally wrong with it!! Any help please!! :? :? :?
  2. slane01
    slane01 Moderator Staff Member
    Mar 8, 2009
    4,369
    Attica, Michigan
    Tyler,
    Welcome to SSW. I am sure someone will chime in shortly with some suggestions for you.
  3. Milk-Lo26
    Sep 5, 2014
    3
    New Athens,IL
    Yeah maybe so slane01 I would like to know something before I reinstall the transmission which has been out of my buggy for 2-1/2 weeks now!! Lol no biggy somebody will know something sooner or later!!lol
  4. commanderjjones
    commanderjjones SSW Rally/Event Director Staff Member
    Jun 1, 2010
    5,153
    Harriman, TN
    Unfortunately, I don't have much experience with the one piece tranny/diff on the 800 like I do the older models.
    Does it act like it's slipping out of gear? Are you certain that it's not the clutch that is slipping?
  5. Milk-Lo26
    Sep 5, 2014
    3
    New Athens,IL
    It seems to be either slipping in and out of differential lock! I'm not sure about clutch but the shop that broke down for me said clutches looked fine were working properly!! Another issue I'm having along with this same situation is with a brand new battery in ranger I can't keep it charged!! Something pulling a constant charge and draining it!! :x :x :x :x
  6. carnivore
    carnivore Registered Member
    Feb 16, 2009
    5,420
    Grand Ledge, Michigan
    Has anyone checked the diff solenoid? Maybe its its defective or maybe the actual switch is defective.
  7. commanderjjones
    Jun 1, 2010
    5,153
    Harriman, TN
    That's a good possibility. Since the diff' automatically defaults to locked when you remove power from the solenoid, it could be as simple as a loose connection to the solenoid......or a bad solenoid or switch as Curt mentioned.
polaris ranger differential unlock acts like neutral
2010 polaris ranger 800 xp transmission solenoid
polaris 800 ranger transmission slipping
polaris ranger 800 transmission
polaris ranger 800xp trans remove
polaris ranger differential lock solenoid location
polaris transmission in buggy
polaris xp 800 ranger transmission 2010
ranger 800 trans removal
