AMSOIL Quickshot SE Awarded Best New Powersports Product by SEMA Judges
AMSOIL Quickshot SE Fuel Additive has been granted the Best New Powersports Product award for 2011 at the SEMA Show at the Las Vegas Convention Center. This year, over 2,000 new products were submitted for consideration of this distinctive honor in various categories. In determining the winners, judges looked for superiority of innovation, technical achievement, quality, consumer appeal and marketability.
AMSOIL Quickshot SE is a premium fuel additive formulated to clean and restore optimal performance in small engine and powersports equipment fuel systems. It acts as a fuel stabilizer between uses and short-term storage and helps prevent damaging corrosion. Its revolutionary formulation focuses on three major fuel-related issues common in small engine equipment: ethanol, water and dirty gasoline.
AMSOIL Quickshot SE is designed to keep water dispersed throughout the fuel tank, moving it out and decreasing the chance of ethanol separating from the gasoline. Moisture finding its way into gas tanks through condensation is dispersed in tiny molecules and safely moved out of the tank through the combustion chamber. The lack of additives in today’s gasoline can cause fuel system gumming and varnish, creating deposits on critical components. AMSOIL Quickshot SE cleans hard to remove deposits on pistons, spark plugs, injectors, carburetors and other combustion chamber parts to maintain peak operating power.
AMSOIL Quickshot SE is recommended for use in all two-and four-stroke gasoline powered engines including motorcycles, snowmobiles, personal watercraft, boats, ATV’s, edgers, tillers, mowers, snow blowers, chain saws, generators and farm and construction equipment.
AMSOIL has been the recognized leader in synthetic lubrication since 1972. For more information about AMSOIL synthetic motor oils and performance products contact your nearest AMSOIL distributor
