Energy-efficient LED Shop Lights From LEDMyplace | Side X Side World
Discussion in 'General Member Discussions' started by fidelmartin7053, Jul 31, 2020 at 8:14 AM.
  1. fidelmartin7053
    fidelmartin7053 Starting Member
    Jun 23, 2020
    7
    If you are the owner of a jewelry shop, you will require a display section and proper lights that will accentuate your sales and business. LEDMyplace a leading brand in the LED industry that sells LED Shop Lights for sale, with product specifics like dimmable, high CRI and CCT, high lumen output. The lights are energy-efficient as they use lights of 8W to 70W replacing 24W to 1000W conventional lighting fixtures. The lights are certified by DLC, ETL, UL, and RoHS making them safe lights for the environment. These lights are suitable for shops because they keep the temperature of the shop at a check. Conventional lighting fixtures produce heat and therefore air conditioning becomes a must, increasing the utility bills. LED lights produce very less heat as only 5% of the total energy consumed is converted to heat the rest are used for lighting. LED Shop lights are a must-have for your shop, see your business grow.
