Looking at the "S" and then back at the 08' there is alot more heat shields on the "S". I have plans to put a 10' "S" exhaust on my 08' and before I put the plastic back on what kind of shield do you think I need to add to protect the plastic?
Bart, Do you have your own brake, shears and welder? Nice job on the shields, I might be interested in a set if you can make me a set, or I might try myself, but I'll have a ton of questions in the process.BlackBart said:Mike,
I posted what I had done for shields under the topic
Exhaust HEAT Shields
You might take a look and see if they are of any help.
Bart
Pops said:Bart, Do you have your own brake, shears and welder? Nice job on the shields, I might be interested in a set if you can make me a set, or I might try myself, but I'll have a ton of questions in the process.BlackBart said:Mike,
Bart
Thanks for the information, it seem lately all I have been working with has been steel of some kind, most the jobs have been too small to setup the chop saw, been using a sawsall for most of the cuts.stroker said:more info; just used a steel cutting skill saw last nite over at my sons shop. made quick work of .250 steel for a truck front bumper. made by makita. blades are costley but don't appear to wear rapidly. we have acces to brakes and shears, but this tool is really handy for the smaller cuts. over kill for your project, but i thought i'd pass it on........stroker
No problem my friend, glad to assistPops said:Now that makes it a lot easier, looking at the pictures I was thinking that the shields were made out of sheet metal and galvanized, I didn't think about the shields being made out of aluminum then buffed. Thanks
Bart I will be asking questions on this project for sure.
