here are some specs. it uses a sym 300cc atv engine with a 4-valve head, ceramic coated cylinder. it has a 54 tooth axle sprocket, climbs like a goat but will only run 35mph for now.
its still stock but I have some goodies for it
Engine
24 hp 300cc SYM Engine w/2 Year Warranty
4-Stroke, 4-Valve Ceramic coated Cylinder
Liquid Cooled Engine
Carburetor
C.V.T. w/Reverse Transmission
EPA/CARB/Euro 2 Certified
Chain Drive
CDI/ Electric ignition
Chassis/Suspension
Steel Frame Body w/ Bolt on CBC
Rack & Pinion Steering
Double A-Arm Front Suspension w/ Strong Struts
Independent Dual A-Arm Rear Suspension
4 Wheel Hydraulic Disc Brakes
Large Utility Rear Rack
Dimensions
LxWxH: 90x62x63"
eatures:
● Headlights w/ Hi-Lo Beams
● Speedometer, Odometer & Tachometer
● Horn
● 12V Power Plug
● Turn Signals
● Brake Lights
● Parking Brake
● Center Rear View Mirror
● Sealed Battery w/Larger Capacity
● Larger 4 gallon Gas Tank
w/Rollover Protection
● 4 Wheel Large Fenders
● 2" Rear Trailer Hitch Receiver
● Cast Ductile Iron Rear Knuckles
w/Sealed Bearings
● Automotive Grade Paint Finish
w/UV Protection on Metal Parts
● 46mph std or 56mph w/Optional 18 Tooth
Engine Drive Sprocket
Wheelbase: 68"
