QuickBooks is an invincible solution widely used by small and mid-sized businesses and freelance professionals to fulfill the accounting needs. Multi-user mode in QuickBooks is a feature that enables users to work on the same Company File simultaneously. QuickBooks H-Series Errors is an inevitable error caused due to internal or external technical glitches. QuickBooks Error H202 occurs when a Workstation fails to communicate with the Company file and doesn’t allow users to access the company file. This article is envisioned to help you analyze the causes of QuickBooks Error H202. The resolution methods are further simplified with easy steps to fix quickbooks h202 Error while you open the company file from a workstation. The actual Error message is illustrated as “You are trying to work with a company file that is located on another computer, and this copy of QuickBooks cannot reach the server on that computer. (H202)”Before you apply the steps to troubleshoot H202 Error in QuickBooks, understanding the causes of Error H202 in QuickBooks is essential. Recognizing the causes QB Error H202 will help you in effective removal of QB Error H202.
