Important Parts Info for the: Can Am | Side X Side World
Discussion in 'Can-Am SXS Discussion' started by RZRRich, Jul 14, 2012.
  1. RZRRich
    RZRRich SSW Director Staff Member
    Apr 28, 2009
    5,457
    3
    [​IMG]
    As the SSW continues to steadily grow it has come to our attention that the need for a central parts information base for the Can Am’s is a necessity. We will be adding to this info base continually and as it filters in from our membership, sponsors, etc. Feel free to make suggestions, submit part numbers, etc. so that we may post them and get the info to our membership.
    We would also like to encourage our membership to use our many sponsors listed at the bottom of the home page.
    Thank you !!
    how to remove maintenance required code on can ams:
    Info provided by: David (bulldogs101)
    in 5 seconds or less do the following:
    turn key on, but don’t start machine.
    1- press override button and hold it
    2- brake on, then brake off, then override off
    now brake only on and then off 7. repeat steps 1&2. all that in less than 5 seconds, power off for 60 seconds and your done
  2. bulldogs101
    bulldogs101 SSW Support Staff
    Nov 15, 2010
    555
    16
    las vegas
    can-am commander torque specs
    Tranny gearbox drain plug = 15 lbf/ft
    Tranny gearbox filler plug = 3.7 lbf/ft (44 lbf/in)
    Front diff drain plug = 5.5 lbf/ft ( 66 lbf/in)
    Front diff filler plug = 17 lbf/ft (204 lbf/in)
    Rear diff drain plug = 5.5 lbf/ft (66 lbf/in)
    Rear diff filler plug = 17 lbf/ft (204 lbf/in)
    Main oil Drain plug = 22 lbf/ft (264 lbf/in)
    Oil Filter screws = 7.4 lbf/ft (89 lbf/in)
    CVT cover screws = 5.1 lbf/ft (62lbf/in)
    all years can am commanders
  3. bulldogs101
    Nov 15, 2010
    555
    16
    las vegas
    lower tailgate seal
    The rear lower tailgate door seal on can am commanders info:
    Be sure to hose out the actual rubber seal on the lower tailgate door if you ride in sand, small gravel area's a lot. blow it off good with a stream of water every month to avoid tears, holes and cracks. once dried wipe a silicone spray lube on the seal and your good.
  4. bulldogs101
    Nov 15, 2010
    555
    16
    las vegas
    commander recall dec 2012
    FYI: commander recall 2012
    if you have certain type of commander, it may have a recall notice on it. its in very specific riding conditions where it applies. if you usually ride in 10 inch or deeper water that is loaded with debris (leaves,grass,moss,straw,etc )then contact your can am dealer AFTER dec 5, 2012 for a recall fix, simple fix, the problem is they feel in that condition only the debris could catch and clog and bunch up on the exhaust pipes coming from engine, when dry then that could cause fire if not cleaned out. going to put a fix there so it dont happen. again, only applies if you ride those conditions. if you dont get a notice from brp, check with your dealer after dec 5, 2012 with your vin number to see if it applies to you.
are there 2 gearboxes in 2012 can am commander
can am commander tailgate
lower tailgate can am commander
oil drain can am commander
where is the gear oil drain and fill plug on a can am commander
