What is the best way to maximize the ground clearance on a 2010 RZRS. I added a 2 inch racer tech lift. Should i mess with my shocks and the pre load? Im not even sure on how to adjust them yet...
You can gain somemore ground clearance by adjusting the shocks, to RZR and turn the preload adjustment down (on top of spring). You will gain some more clearance, but also make your ride more firm.
You can put larger tires on it, if you do I would stay with 12" wheels, the tires will have more sidewall and give you more bounce.
1 - 2 of 2 Posts
A forum community dedicated to Side by Side vehicle owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, troubleshooting, maintenance, and more!
