Dominator Coolant Boost is formulated with proprietary tiered surfactant technology, providing quick and effective heat transfer inside radiators and cylinder heads, which results in reduced operating temperatures, more efficient operation, increased horsepower and significantly reduced engine warm-up times in cold weather. Coolant Boost also contains a robust mixture of corrosion inhibitors that protect the radiator, heater core, water pump, cylinder heads, engine block and intake manifold from the damaging effects of corrosion.
Recommendations
Dominator Coolant Boost is recommended with both racing applications using straight water coolant and automotive applications using 50/50 coolant/water mixtures.
When mixing with 50/50 antifreeze and water, add 1 fluid ounce of Dominator® Coolant Boost for every quart of 50/50 mix. With straight water coolant, add 2 fluid ounces of Dominator® Coolant Boost for every quart of straight water coolant.
Package sizes include:
16-oz. bottle
16-oz. bottles (case of 6)
--> For more information, pricing or to place an order
Questions and Answers about Dominator Coolant Boost
