AMSOIL is introducing its latest line of synthetic motor oils. AMSOIL OE Synthetic Motor Oils are specially formulated for the longer oil change intervals recommended by vehicle manufacturers today. Available in three viscosities, 5W-20, 5W-30 & 10W-30, this advanced synthetic technology resists chemical breakdown for maximum wear protection (and peace of mind) well beyond the traditional 3,000-mile oil change interval.
Click HERE for more information and Pricing
AMSOIL OE Synthetic Motor Oils help provide better wear control, high- and low-temperature protection and increased fuel economy compared to conventional oils. The oil drain interval recommendations for many of today’s vehicles extend well beyond the traditional 3,000-mile interval, some up to 12,000 miles with electronic oil monitoring systems. AMSOIL OE Oils provide excellent protection and performance for the entire length of the original equipment manufacturer’s recommended drain interval.
AMSOIL, the leader in automotive synthetic lubrication, produced the world’s first API-qualified synthetic motor oil in 1972. Trust the extensive experience of AMSOIL, The First in Synthetics®, to do the best job protecting your engine.
Improve Fuel Economy
Formulated with friction modifiers, AMSOIL OE Synthetic Motor Oils are fuel-efficient oils that reduce friction-related energy loss. They provide better fuel economy compared to conventional, non-fuel-efficient motor oils.
Maintain Low Emissions
AMSOIL OE Synthetic Motor Oils are friendly toward modern emissions control systems, promoting proper operation of catalytic converters for optimum service life and low exhaust emissions.
Protect in All Temperatures
AMSOIL OE Synthetic Motor Oils are multi-viscosity formulations. They resist the effects of thermal breakdown, including evaporation and viscosity loss, while remaining fluid in cold temperatures for easier cold starts and fast start-up circulation.
Keep Engines Clean
Fortified with high levels of detergent and dispersant additives, AMSOIL OE Synthetic Motor Oils are engineered to resist sludge and carbon deposits better than conventional oils. They promote clean operation for longer-lasting, better-running engines.
APPLICATIONS
AMSOIL OE Synthetic Motor Oils are excellent for use in all types of gasoline-fueled vehicles. They are recommended for all domestic and foreign vehicles requiring any of the listed performance specifications.
COMPATIBILITY
AMSOIL OE Synthetic Motor Oils are compatible with conventional and other synthetic motor oils. Mixing AMSOIL OE Synthetic Motor Oils with other oils, however, will shorten the oil life expectancy and reduce the performance benefits. Aftermarket oil additives are not recommended for use with AMSOIL OE Synthetic Motor Oils.
SERVICE LIFE
In gasoline-fueled vehicles, AMSOIL OE Synthetic Motor Oils are recommended for the intervals stated by the vehicle manufacturer or indicated by the oil life monitoring system. Change oil filter at every oil change.
Spec's
5W-20 (OEM)
API SN, SM...
ILSAC GF-5, 4...
GM 6094M
Ford WSS-M2C930-A
Chrysler MS-6395N
5W-30 (OEF)
API SN, SM...
ILSAC GF-5, 4...
Ford WSS-M2C929-A
Chrysler MS-6395N
GM dexos1™ (supersedes LL-A-025,
6094M and 4718M)
10W-30 (OET)
API SN, SM...
ILSAC GF-5, 4...
GM 6094M, GM 4718M
Chrysler MS-6395N
Keep Engines Clean
APPLICATIONS
COMPATIBILITY
SERVICE LIFE
Spec's
5W-20 (OEM)
API SN, SM...
ILSAC GF-5, 4...
GM 6094M
Ford WSS-M2C930-A
Chrysler MS-6395N
5W-30 (OEF)
API SN, SM...
ILSAC GF-5, 4...
Ford WSS-M2C929-A
Chrysler MS-6395N
6094M and 4718M)
10W-30 (OET)
API SN, SM...
ILSAC GF-5, 4...
GM 6094M, GM 4718M
Chrysler MS-6395N
