1 - 1 of 1 Posts
Polaris: How to take up throttle cable slack.
__________________________________
FYI, The adjuster is about 8" before the throttle body.
Adjustment:
1. Remove the seat.
2. Locate the throttle cable adjuster.
3. Squeeze the end of the rubber boot and slide it far enough
to expose the end of the inline cable adjuster.
4. Loosen the adjuster lock nut.
5. Rotate the boot to turn the adjuster until 1/16" to 1/8"
(1.5 - 3 mm) of free play is achieved at the throttle pedal.
NOTE: While adjusting, lightly flip the throttle pedal
up and down.
6. Tighten the lock nut.
7. Squeeze the end of the rubber boot and slide it over the
cable adjuster to its original position.
(Info provided by - 'azbohunter')
1 - 1 of 1 Posts
