By Jon Crowley, UTVGuide.net and Joey DiGiovanni, UTVUnderground.com Up until today there has only been 2 true SPORT UTV models to select from and both happened to be made by Polaris. The Polaris RZR S was the first sport minded UTV to hit the market, equipped with factory long travel suspension. RZR S changed the UTV game all while giving consumers the option to buy a UTV that came with the type of suspension usually reserved for the aftermarket. In January of 2011 Polaris trumped themselves and the entire industry with the release of the Polaris RZR XP 900. The XP 900 immediately jumped to the top of the list for consumers who wished to buy a UTV from the dealership with both suspension and POWER! Polaris changed the game with the new XP 900, boasting a rear trailing arm suspension design that resembled that of a sand car and a new, larger power plant. The XP 900 has now become the go to UTV for those looking for a true SPORT UTV. Well now the game is being changed once again. However, this time it is not by Polaris. In July Arctic Cat busted on the scene with their new answer to the XP 900 and the entire craze surrounding the SPORT UTV market. Arctic Cat introduced the 2012 Wildcat Sport UTV. Much like the RZR XP 900 by Polaris, the Wildcat will utilize a trailing arm rear suspension, which just happens to boast industry leading wheel travel. Arctic Cat did not ignore the power side either, powering the machine with their 1000cc V-Twin 4 stroke. Now sport minded consumers are asking the question, Wildcat Vs. RZR XP 900? So we decided to take the numbers and crunch them down giving you your first comparison between the 2 most talked about UTV’s of the year. In the open desert and dunes, there are a few factors that make a vehicle perform well: Power Suspension Travel and High Quality, Adjustable Shocks Lightweight Wheelbase – longer wheelbase tends to help in the whoops Width – wider platform is more stable Low Center of Gravity / Seating Position Polaris RZR XP 900 vs. Arctic Cat Wildcat 1000 Suspension The Wildcat boasts some incredible wheel travel at 17″ in the front and 18″ in the rear. This will be a huge asset in the dunes. Head to head, the RZR XP 900 and the Wildcat look to have similar horsepower numbers. Based on the weight difference, we believe the Wildcat would lose in a straight line, smooth terrain hill shoot. But where the Wildcat may shine is when you toss in some whoops or rough terrain. With 8.5″ more wheelbase and 3″ – 4″ or more wheel travel, the Wildcat should be able to keep the available power to the ground better. The Wildcat and RZR XP 900 both feature rear trailing arm suspension. Arctic Cat has opted for a 5-link and Polaris for a 3-link. The Wildcat has 2 inch adjustable Walker Evans Racing shocks with piggyback reservoirs. The RZR XP 900 has 2 inch adjustable Fox Racing Shox with piggyback reservoirs. Both of these suspension types have a long history in off-road racing and provide improved performance over typical a-arms when it comes to high speed and rough terrain. Both shock types are also customizable when it comes to valving and dampening. What we mean is if the supplied adjustments still are not giving you the “tune” that your riding style requires then you can have them pulled a part and fine tuned to your liking by a shock expert or by FOX Racing Shox and Walker Evans Racing themselves. This is huge especially for the consumer who plans to compete with their new UTV. One area where the Wildcat has an advantage is wheelbase. Wheelbase is the biggest reason why UTV’s of the past tended to nose dive when air-born or went through the whoops in a very uncomfortable manner. With added wheelbase the UTV is going to traverse the whoops in more of a rhythm. Perfect example is the Polaris RZR-4, which is not included in our comparison for obvious reason, but if it was it would be arguably the smoothest UTV in the big bumps due to its added wheel base. The Wildcat is not only 11.5″ longer overall, but the Wildcat’s 90-inch wheelbase is 8.5 inches longer than the RZR XP900. The only downfall to this extra length is getting it to the dunes. Many dune riders have tight circumstances in their trailers and another foot can be a big deal. Engine The heart of the new Wildcat 1000 is a 951cc V-Twin, SOHC 4-stroke with Electronic Fuel Injection (EFI). This engine has proven itself on the Prowler XTZ. On the Wildcat, the 1000 H.O. has been tuned to deliver even stronger acceleration thanks to the extra torque and horsepower provided by heavy-breathing 50mm throttle bodies, a new 2-into-1 ceramic coated exhaust and an all-new air intake system. At the heart of the RANGER RZR XP 900 is the all-new, 88 horsepower ProStar™ 900 Twin EFI engine that was built specifically for an extreme-performance Side x Side. The engine features Dual Over-Head Cams (DOHC), four big valves per cylinder and a 180-degree crankshaft for balanced performance and fast throttle response for groundbreaking acceleration. Engine placement is also important in the design of the chassis and seating. Both of these vehicles place the engine behind the seat which helps in a few ways. It allows the seat position to be lowered for a much better center of gravity and also helps produce a better front-to-rear weight ratio. Off-road vehicles tend to handle rough terrain better if the rear of the vehicle carries a little more weight than the front (e.g. 60-40 ratio). Getting the front end up in the whoops will help the car maintain speed and drivability and with a little more weight in the rear the UTV will tend to fly a bit more level vs. nose diving like earlier model UTV’s. Power Steering Arctic Cat’s Variable Assist Electronic Power Steering (EPS) on the Wildcat delivers even greater steering control and ease. The EPS system is a managed electronic control unit (ECU) that measures steering input force, tire resistance and vehicle speed, and then provides the appropriate assist to the steering column through an electric motor. The RZR XP900 does not come standard with power steering, but it is available as a PURE Polaris accessory and also from Wicked Bilt. The RZR XP 900 has the wiring in place to easily install the Pure Polaris power steering unit. Something tells us that a future XP900 will come factory with EPS but for now the Wildcat has the edge in terms of factory provided EPS. We love power assist steering for UTVs and think that it is great that it is available for both of these vehicles. We really like EPS when traversing trails or rocks at a slower pace. When at speed it is a little less important but at those low speeds EPS can really help you along. If you are a fan of EPS as well, factor that into your cost comparisons since you would need to add that to the RZR XP 900. Weight When you are looking at a vehicle that has less than 100 horsepower, more weight is a performance killer. The claimed dry weight of the Wildcat is 115 lbs. heavier than the RZR XP 900. Both vehicles have enough horsepower to push the cars nicely through the dunes, but if the horsepower of these vehicles is nearly equal, the RZR XP 900 will win the straight-line race. Keep weight in mind when modifying your UTV as well. We hear lots of complaints of not enough power from consumers but then we look at their UTV’s and find they have loaded it up with an extra couple hundred pounds of accessories! With that said, you never want to jeopardize safety for the sake of saving Specification Comparison Polaris RZR XP. Arctic Cat Wildcat Dry weight. 1190 lbs. 1305 lbs. Ground clearance. 13". 13". Length. 108.4". 120" Width. 64". 64" Wheelbase. 81.4". 90" Travel. 13.5"/14". 17"/18" Engine. Twin-875cc. Twin-951cc Bed capacity. 300 lbs. 300 lbs. Tilt wheel. Yes. Yes. Center of gravity rating. 9. 10. Power steering. No. Yes MSRP. $15,999. $16,599 Conclusion: Competition is a good thing! We are thrilled that another manufacturer has entered the pure-sport UTV market with a vehicle that makes dune and fast paced off-road riding fun. There is a HUGE market for sport UTVs, and Kawasaki, Honda, Yamaha and Suzuki should take note. Crowley Offroad has a Polaris RZR XP 900 demo unit that we use for testing and reviews. We hope to have an Arctic Cat Wildcat in the stable soon so we will be able to bring more details and comparisons forward. Until then keep tuned in to see where the industry goes. Who knows what may come next?
