2005-2008 Rangers:
Up to 27" tall tires: You can fit these tires on a stock machine. There may be slight rubbing under hard driving with the 27" tires.
28" to 30" tires: You can fit these tires using a 2" lift. Some have installed the Super ATV 2" forward a arms to give them a little more clearance. Only Super ATV makes forward a arms for these years.
2009-2010 Rangers:
Up to 27" true height tires: You can run 27" Tall tires with a 2" lift, but some tires such as 27" Bighorns are 28+" tall and will not fit with a 2" lift.
28" and taller tires: These tires require 2" forward a arms with a 2.5" lift from Ranger Pro Lift or the highlifter floorboard cutout kit.
Only Ranger Pro Lift makes forward a arms for these years.
