PRIMARY (driver or driving) CLUTCH OVERVIEW
The main purpose of the Primary Clutch is to control the engine speed throughout all shift ratios. Simply stated, it has to hold the RPM’s at the POWER(Torque) range while it changes the gear ratio. The clutch itself is comprised of many parts, however for simplicity, I will only describe the main ones.
The clutch contains 2 surfaces that the BELT rides up and down between. These are called Sheaves. One is stationery and the other is moveable. The movement these sheaves,(open or closed) and well as the movement of the belt is controlled by and dependant upon the Flyweights and Spider.
1. Fixed Sheave
2. Moveable Sheave
3. Pressure Spring
4. Flyweight (the actual weight is expressed in grams-Polaris)
5. Flyweight cam surface(spider) and roller
When the engine is running, the Primary Clutch is spinning or turning in relationshipto the RPM’s, Faster or Slower. As the RPM’s Increase (rotational speed at which the clutch is turning), centrifugal force is being applied to or created by the Flyweights and this force is transferred thru the roller and spider. This force is them being applied against the moveable sheave, forcing it to be compressed against the fixed sheave. This compressing action is what moves the belt up/down between the sheaves. Obviously there must be a method of holding or controlling this force otherwise the Flyweight would just be thrown out of the clutch. This leads me to the final key component, the Pressure Spring. The purpose of the Pressure Spring is to hold back and control the centrifugal force being created by the Flyweights revolving are a fixed point.
NOW RIGHT ABOUT NOW, YOU’RE THINKING, OK I’M LOST AND I’M NOT AN ENGINEER. Well neither am I, but I can give you a good example of what’s happening. Ever hear of David & Goliath, well if you haven’t, I not going in to that subject matter. But anyway, David was using 2 pieces of string, tied to either end of little pouch, into which he would place a rock. He would then hold the string in one hand with the rock dangling below in the pouch. He would then begin to swing the rock supported at then end of the string, ROUND and ROUND, until he had sufficient FORCE generated to release one of the strings and hurl the rock as fast and as far as possible.
The strings can be compared to the Pressure Spring and the rock is compared to the Flyweights and his Strength to spin this contraption is the Engine RPM’s. Heavier rock meant he had to exert LESS strength to make is spin faster, lighter rock meant he had to exert MORE strength to accomplish the same task. SO, heavier Flyweights require LESS RPM’s, lighter Flyweights require MORE RPM’s. The string is like the Pressure Spring, LESS spring rate is like shortening the length of the string meaning he had to exert LESS force to get it to spin, MORE spring rate is like lengthening the string meaning he had to exert MORE force to get it to spin. THIS ENDS THE LESSON BY ST.BART,YeeHaa
.After the Flyweight is thrown outward, the force generated by this action has to work against the pressure spring and some load applied the Secondary Clutch. In order to control the engine speed changes, the Flyweights and profile(the way the flyweight is designed) have to be matched to oversome the spring pressure at the right point on the shift curve.
There are 7 areas(these are described in good detail in Aeen Olvans book, to be considered in balancing the Primary Clutch system:Summarized Quotos Follow:
Free Wheeling-At engine speeds below engagement, the pretension load of the pressure spring is larger than the flyweight force
Engagement-When the sheaves engage the belt, the flyweight force is just overcoming the pretension of the pressure spring
Clutching-The clutching phase begins when the flyweight force overcomes the pretension, and lasts until the flyweights have generated enough side force to transfer the engine torque without slipping the belt
Low Acceleration-Between full engagement and the shift point, centrifugal forces are larger than the pressure spring but less than the belt pressure from the driven clutch
Shift out Point-The shift out point occurs when the flyweight force overcomes the belt pressure from the driven clutch
Straight Shift-Straight shift is obtained by matching curvature and spring rates, correct engine speed is dependent on the weight of the flyweight
Over-Run-In over-run, the clutches are shifted all the way out and the flyweight forces have no more influence on the engine speed. Engine speed will increase along the fixed high ratio line
The picture below is taken directly from the book and more or less describes the ranges in a graph fashion, which I think is pretty easy to follow.
1. Fixed Sheave
2. Moveable Sheave
3. Pressure Spring
