Sure Power Battery Isolator:
_____________________________
The Sure Power Battery Isolator eliminates multi-battery drain when two or more battery banks are in a charging system. They isolate each battery circuit and allow each battery to discharge and charge according to its own needs. The battery isolator was invented by Sure Power in 1959, they are more efficient and reliable than mechanical or solenoid systems and are the most comprehensive line of battery isolators on the market.
http://www.ase-supply.com/Sure_Power_Battery_Separator_s/154.htm
http://www.ase-supply.com/Sure_Power_Battery_Isolator_Battery_Separator_s/20.htm
http://www.fourwheelcampers.com/batteryseparator1315.pdf
Check with our many sponsors as well. :wink:
