bulldogs101 said:
so i have a rnager crew year 11.
it come from dealers on 13 pds pressure. if im going to ride on mainly sand should i drop the pressure, or not worry about.
I always lower mine to about 4-5 lbs, but not sure for long term riding.
Thanks Gary. A person locally mentioned they had there's down in the 5-6 pd range, but that did not seem right to me...
heck 13 pounds seems low to me...lol...
but at least now I know it is correct... thanks for the tip
David, I'm running the Pitbull's on my RZR. For normal trail riding I run 10 - 12 psi but if I run the dune's I drop it down to 4-5 psi and haven't had an issue in doing so.
I run 4 pounds in my Bighorns in the sand.
I run 4lbs with bead locks and paddles. With ITP off road tires on the XP I personally run 4-5lbs if the ride is slower and there are passengers. On faster harder rides I use 6-7 lbs max.
