Car to Car Radio Install
I finished the install of the Rugged Radio Car to Car system here are some pictures. I already had the intercom system installed and working.
I did reroute the existing headset intercom cables to the back seat and added two additional cables for helmet intercoms for the grandsons. The male end of the cable is different for each type. I wanted the ability to use either headset or helmet.
Existing intercom the clear plastic in the background protect as second set of cables running to the rear seats:
XM receiver and car to car in glove box. I considered mounting the intercom here but I needed to reach the squelch knob on the intercom while driving so I left it under the dash.
This is the antenna mount using an Axia Alloy whip mount. With the soft top on the cables will be hidden. The antenna will be removed when trailering and I found a plastic bottle cap to protect the connection.
This is the helmet intercom set that will go in the boys helmets.
I also added a mount for my GoPro helmet camera and since I had the trail tires on Ranger I took a test ride around the block taking video. It worked fine so hopefully I will have some good videos and pictures to post after President's Day.
Gee there is never enough time and money to do everything you want to do to your toys.
